Home Forums Sign Making Discussions Vinyl Dry wipe material
  • Dry wipe material
    Posted by Marcella Ross on 17 August 2005 at 10:03
    I have a customer looking for some signs which he wants on a dry wipe surface so that they can change some areas where necessary. The signs need to be cut to size and will have mainly vinyl text but a blank area for them to write on also. Can anyone point me in the direction of where I could buy sheets of dry wipe type material or a suitable alternative?
    Marcella
    Marcella Ross replied 20 years, 3 months ago 9 Members · 12 Replies
  • 12 Replies
    17 August 2005 at 10:15
    Go to your DIY store and buy a 4×8 sheet of white tileboard. You know, the stuff folks use when remodeling the bathroom in their trailer. ๐Ÿ˜•
    Also known as Marlite or Abitibi board.
    It’s under $10 here.
    Pick the best-looking sheet in the stack.
    Sometimes it comes masked.
    Cut it to size with a new blade, being careful not to scratch it.
    Sand the edges with a hand-held block sander.
    Clean with Windex and apply vinyl lettering.
    Then wax with regular aerosol furniture polish.
    Instant hillbilly dry-erase!
    You can frame it with regular basebord material, but I don’t because I can’t cut 45ยบ angles.
    Tell the client to periodically clean it with Windex, and re-wax as needed.
  • Chris Hooper
    17 August 2005 at 10:18
    Metamark do a dry wipe vinyl 160 micron for use with water based dry wipe markers on interior applications – used it many times AOK
    1-24 metres ยฃ8.42 per metre on 760mm width
    Metamark
    Telephone08453455645
    17 August 2005 at 10:21
    thanks guys.
    The vinyl may be an option… didn’t know Metamark did that. I could apply a strip of this to the area they want to write on I suppose… got me thinking…
    thanks! ๐Ÿ˜€
  • Andy Gorman
    Alternatively, you can buy dry erase vinyl. I think KPMF (spit!) do one.
    Edit: Beaten to it.
  • Dave Bruce
    17 August 2005 at 10:27
    Contact Drytac 0117958 6500, they do a laminating film especially for dry wipe applications, it is very thin, clear and easy to apply. I use it on powder coated A boards, swing pavement signs and Foamboard signs. Usually I just cover the whole sign with it so the surface has the same look/sheen throughout.
    17 August 2005 at 11:59
    Dave,
    the laminating film, do you just apply this as you would vinyl?
  • Andrew Butler
    17 August 2005 at 12:22
    Don’t know if this would be suitable for what you want, but we made a dry wipe work board for our shop using forrex top (foamex ultra) used it for two years now and it works a treat as a dry wipe board.
    Hope this is of some use
    Andy
  • Dave & Rob Lowery
    17 August 2005 at 12:35
    Try a traffolite type engraving laminate engraving laminate. This is just the same as formica and comes in various thicknesses and colours and sheet sizes 4′ x 4′ and 4′ x 2 ‘
    Contact Surgrave on 0191 417 4505 and ask for a price on their Rigid Laminates.
  • Dave Bruce
    17 August 2005 at 13:04
    That’s what I do Marcella, all done by hand. The great thing with this stuff is it is not expensive and you can apply it over different surfaces, depending on what the sign is. I use to use a much thicker laminate but it was difficult to apply over vinyl and had a slight colour to it thus reducing the vinyl colours, this stuff is really thin(65mic) and clear.
    It is called Protac Scribe 648mm X 25m ยฃ46 last year, it is the stuff they put on year planners etc.
  • Iain Gordon
    17 August 2005 at 17:13
    I was messing about with this the other week and i found that white vinyl works a treat, didnt leave any residue.. this was a cheapo vinyl at about 75p a meter megarex i think they call it
    Iain
  • Carrie Brown
    17 August 2005 at 17:57
    Also make sure the client uses the right pens for the material …… we made some in house and being melon heads hastily bought some pens and they wouldnt wipe off ๐Ÿ˜ฎ ๐Ÿ™„ after lots of complaining about the board blah blah blah ….. then after a little reserach we realised that you have to get the right pens …….. I mean I thought dry erase pens were the same as the pens that do work on the board cant even remember the name now …. ๐Ÿ˜ฎ crikey Im confusing myself now ……. never mind … I hope you get my point??
    :lol1:
    17 August 2005 at 18:43
    I know what you mean Carrie…. even if you got yourself lost! ๐Ÿ˜€
    I called Drytac Dave, they’re sending me a sample for me to try out, 1000 x 6000mm!!! More than I need to do the job! ๐Ÿ˜€ ๐Ÿ˜€
