Home Forums Vinyl Cutter Discussions General Cutter topics Drivers for Mutoh MC650S CAN YOU HELP FOR XP
  • Drivers for Mutoh MC650S CAN YOU HELP FOR XP
    Posted by steviebee on 2 August 2008 at 09:32
    Hi Guys and Girls
    I m really trying hard to find some or even one Driver for my Plotter its a rather old but still as new Mutoh MC 650S and after trying everywhere even Mutoh no help available Have you got this Model is it working with windows or apple can you help me set this up.
    I am using VMP and Sign Lab and lots of others but no drivers found tried looking for a emulation even tried changing in the windows as by vmp help but not able to get it to work!
    It runs a full test so its fully working… Go on help and I will be forever i n your Debt
    Cheers Steve
    mod-edit
    steviebee replied 17 years, 4 months ago 3 Members · 4 Replies
  • Frank Droog
    9 August 2008 at 14:54
    Cant find a manual for it.
    But found a spec sheet for it by googling.
    The spec sheet says the plotter can be set for MH-GL or HPGL2
    You probably can toggle the setting via a menu on the plotter somewhere.
    Im reasonably sure if you set it to HPGL2, then any Signlab Mutoh driver should make it cut.
    What if any errors are you getting when you try to cut?
    frank at cadlink
  • steviebee
    9 August 2008 at 15:02
    Hi Frank, Thanks for that info, I have tried that and also my software with my Rip vmp WILL ONLY CUT SAMPLES, when I set it up to cut it say unidentified in the read out and fail because unknown printer from my computer.
  • Tim Painter
    9 August 2008 at 22:07
    You should be able to find a driver for a Mutoh SC650, I would give that a go.
  • steviebee
    10 August 2008 at 09:51
    Cheers Frank I will give it a try,I today used my Vinyl Master Pro and it has cut out all my sample cuts so I may have at last found that driver ?
    So Thanks for your help and if I can be of help in return I will cheer Mate.
