Home › Forums › Software Discussions › Adobe Software › Drawing a border line in Illustrator CS4
Posted by TomPreston on 18 August 2010 at 10:29Hi.
This may seem like a ridiculous question, but I’m looking for a quick and easy way of drawing the attached shape in illustrator.I am currently using Graphix Advantage Composer 6.2 to do my designing, which features a tool which allows me to simply draw out the shape and set the corner radius’ I need.
However I am struggling to find a way of making this shape quickly in illustrator, (the way I do it at the moment is draw a box at the back and 4 circles in front, then ‘minus front’ in pathfinder).
This is very time consuming compared to the way and accuracy I can do it with Composer.
Is there a plugin which allows me to simply draw this shape?
Also, does anyone know the correct name for this shape?! It may help me in searching for a solution.
Many thanks,
Tom
Jan Storgaard replied 15 years, 3 months ago 7 Members · 12 Replies -
Draw a rectangle, Then 4 Circles place onto corners and hit minus in the pathfinder
tool -
quote Mathew Gibson:Draw a rectangle, Then 4 Circles place onto corners and hit minus in the pathfinder
toolThanks for the reply, but that’s the way I already do it.
I’m looking for a quicker solution if that is possible?
Make a brush stroke that has those corners. Draw a rectangle, apply the stroke.
Just remember to expand the path if you want to be able to cut it.
quote TomPreston:Hi.
Mathew posted the solution. I would make 5-10 different rectangles with different inverted corners AND make a symbol library for easy access.
I DONT think the brush solution is helpfull, its a pain to make many different sizes and it not a path unless you expand and combine after (takes to long)Seach criteria: Border corner inverted negative frames ornament vector
Jan
How quickly do you want to be able to draw it?
With smart guides turned on so that the circles snap to the corners, that shape could be created in 10 seconds.
Then just save in a file for future use.
quote Peter Normington:2 seconds in signlab,
Peter 😀1 millisec from symbol library (:)
no offense ;O)
Many thanks,
Tom
Tom, if you like, i can make you a screencast of it. Takes me 2 minutes. Drop me a mail if you want it…
Peter 😀I’m considering trying signlab to see if it is a more suitable upgrade for me. I’m finding doing things in illustrator is taking a lot longer than it does in composer.
Is signlab a similar program to composer?
Is there a trail version which I can download?
Thanks for all your help guys
If You go to the cadlink.com website there is a demo download, and also videos etc what signlab can do
The shapes are already there Illustrator to edit to suit your own requirements.
Goto window – brush libraries – borders.
quote Kev Mayger:The shapes are already there Illustrator to edit to suit your own requirements.
Did you try making a usable cutline from it ?
It will turn into many paths and nodes and make a poor cutfile.
You make be able to make a useable cutline, but then its quicker to do the rectangel and 4 circles stuff!….
ALSO sometimes you need different radius on corners and brushes dont have that.
