Home Forums Sign Making Discussions File Swapping dragon i need
  • Derek Heron
    7 May 2005 at 19:57
    try this one it looks ok
  • Richard Urquhart
    7 May 2005 at 20:05
    onestop the one dex has done is fine mate youe one did have cuts through i a few places
  • L J.
    7 May 2005 at 20:56
    still got minor prob at tail, nothing to get excited about though
    L J
  • onestopsigns
    7 May 2005 at 20:59
    thanks you lot are the best most appreciated will give that 1 a try tommorrow morning
    wat are the error with the tail ?out of the cuts ive done most failed at the tongue tail or front claw
  • onestopsigns
    7 May 2005 at 21:00
    and how do u see if they cuts through them ?
  • L J.
    7 May 2005 at 21:06
    if I’m right you are using flexisign, yes!
    if so just click on the yellow box on the left at bottom of tools, this takes the colour out of drawing, (wire frame) then zoom right in to the tail.
    if you want i will sought it & re post it now for you to cut tomorrow
    L J
  • L J.
    7 May 2005 at 21:17
    here you go
  • onestopsigns
    7 May 2005 at 21:20
    thanks for that lj most appreciated and will have a look at flexi to see if i cant work out to fix it me self had the same problem with a football clubs badge not long ago
    but i useally use artcut but the flexisign7.5 i used to day was simple yet i started on flexi 6 could not master it . i take it we alter the pic in corel not flexi ?
  • L J.
    7 May 2005 at 21:38
    you don’t need any other prog except flex 7 it does everything i can think of
    L J
    7 May 2005 at 21:47
    are your cut lines on any of these joins? or are they in other parts of the graphic?
  • onestopsigns
    7 May 2005 at 22:52
    i seem to have a line going through his eye to his foot
  • L J.
    7 May 2005 at 23:04
    if you import dragon 3 that i posted you should find it is perfect in flexi
  • L J.
    7 May 2005 at 23:13
    by the way the black line around the dragon 3 is the size you quoted, to show you that you cannot make it that size without stretching it.
    L J
  • Jayne Marsh
    8 May 2005 at 09:29
    In Flexi open new file and use the import command to import the file that dex posted for you. This file is perfect in flexi and will require no welding or anything else. You should be able to cut this from flexi with no problems.
    I would suggest you forget your other software programmes and concentrate on learning Flexi, it is very good and easy to use and should give you no problems.
  • L J.
    8 May 2005 at 09:37
    Jem,
    The file you mention has a fault near the tail, i have cleaned it up & posted it as dragon 3
    L J
  • Jayne Marsh
    8 May 2005 at 10:01
    sorry didnt notice that 😳
  • Jayne Marsh
    8 May 2005 at 10:04
    Just taken a closer look, well spotted !
  • Simon Clayton
    8 May 2005 at 15:17
    Try this one.. “Japanese Dragon simon” it’s in corel draw format
    Just change it, fault in tail gone…??
    Simon
  • L J.
    8 May 2005 at 15:36
    try this also, straight into flexi
    😳 O dear flexi ext not allowed for some reason
    L J
    Simon: that version in corel has still got the fault on the tail!
    L J
  • Simon Clayton
    8 May 2005 at 16:34
    Well spotted LJ, just uploaded new one, i open it in corel exported as EPS and opened it in flexi , no problems,
    Simon
  • Simon Clayton
    9 May 2005 at 19:17
    Four leg one….. 😳
    Simon
  • onestopsigns
    9 May 2005 at 19:31
    ok i must be doing some thing wrong
    al these u say will cut fine end up not cutting in my shop
    all i do is import the ai image to flexisign stretch it to size by dragging the edges then press cut button
    it then goes to cutter and cuts then it just decides to add lines
    now when import it i cant see any lines that shouldnt be there
    so i just dont understand it i really dont
