Home Forums Sign Making Discussions Vinyl Double sided printing effect
  • Double sided printing effect
    Posted by Nick Tunstill on 16 January 2014 at 16:34
    A customer of mine wants a printed vinyl to go on an internal glass panel that can be read from both sides. I imagine it could be done by reverse printing on clear then sticking a printed a printed vinyl on the back but does anyone have any other simpler ideas/
    Many thanks
    Nick
    Stuart Davies replied 11 years, 9 months ago 5 Members · 5 Replies
  • David Rogers
    16 January 2014 at 18:39
    http://www.uksignboards.com/viewtopic.p … highlight=
    discussed similar here.
    Transparency issues best solved with a blockout layer – so likely to be
    REVERSE PRINT ON CLEAR
    BACKED OFF IN WHITE
    BLACK LIGHT BLOCK
    PRINTED ON WHITE
    CLEAR LAMINATE
    Bit of a mission to mount for application all in one go, I normally split to 3+2 layers. (or 2+2 if no light bleed through issue eg, dark prints with low contrast)
    Of course, you could always just apply from both sides…
    16 January 2014 at 20:22
    Can’t you just stick one on one side of the glass & one on the other?? Still need to think about a blockout layer on at least one of the sides
  • Nick Tunstill
    17 January 2014 at 08:43
    Many thanks most helpful
  • Fabrice Menard
    20 January 2014 at 15:33
    http://www.youtube.com/watch?v=o26M8YeU … e=youtu.be
    http://www.youtube.com/watch?v=GcMpWTCw … e=youtu.be
    here was blockout printable vinyl used for the exactly same purpose you are looking for.
  • Stuart Davies
    20 January 2014 at 19:38
    That makes the job look so easy
    stu
