Home Forums Sign Making Discussions General Sign Topics Double sided brushed aluminium material required
  • Double sided brushed aluminium material required
    Posted by Warren Beard on 5 July 2012 at 09:45
    I need to maker some projection signs for a customer but they want them to be brushed finish and I can’t find a double sided brush finish material. I’ll have to flood coat a panel with brushed vinyl finish to achieve it but though I would find out if anybody knows of a product that already exists?
    Warren
    David Rowland replied 13 years, 5 months ago 5 Members · 7 Replies
  • 7 Replies
  • Tim Painter
    5 July 2012 at 10:46
    Not sure how your creating them but can’t you just back to back sheets?
  • Warren Beard
    5 July 2012 at 11:36
    quote Tim Painter:
    yes but would just cost more than using vinyl and then I’ll have to bond them togather and make sure it’s straight and then it would be thicker with 2 black edges (if using composite)
    Thought I would check first if anybody knew of any ready made materials out there.
    Warren
  • Lee Reeves
    5 July 2012 at 14:15
    Most sheet metal companies could supply you with brushed stainless steel cut to size that way you don’t get the ugly black edge that or it alluminium grained but the it would need anodising to stop it corroding.
    5 July 2012 at 15:51
    remember vinyl and sheet might not match together
  • Warren Beard
    5 July 2012 at 22:42
    quote Dave Rowland:
    Yeah which is why I was oing to use a grey foam board and apply printed brushed vinyl to both sides
  • Chris Hansen
    6 July 2012 at 02:54
    The Avery brushed aluminium has the same finish on the adhesive as the front.
    6 July 2012 at 14:11
    printing black on what looks like silver… does indeed produce stunning results.
