Home Forums Printing Discussions Roland Printers Double sided Banner print?
  • Double sided Banner print?
    Posted by Dan Osterbery on 12 May 2009 at 10:47
    Hi guys,
    I’ve never printed anything double sided on the versacamm before and have to do a double sided banner. Ive looked in the help files but cant find anything about double sided prints?? How do we get things to line up?? Any tips appreciated.
    thanks
    Dan
    Gavin MacMillan replied 16 years, 7 months ago 2 Members · 2 Replies
  • Steve McAdie
    12 May 2009 at 10:52
    Hi Dan,
    Asked the same question as you a while back. I did it as Dave suggested and it turned out great.
    http://www.uksignboards.com/viewtopic.p … ght=banner
  • Gavin MacMillan
    12 May 2009 at 11:41
    I’ve done plenty as Jason suggest in that thread, all worked a treat.
    Make sure the material is square when you print both sides and line up to your pin hole and it should be fine, put plenty bleed on if your worried.
    One issue can be the material sticking when you print the second side the ink on the heater) causing a motor error. Make sure the first side is completely dry before flipping and doing the second side.
    G
