Home Forums Sign Making Discussions Vinyl Does anyone make a machine that applys application film
  • Does anyone make a machine that applys application film
    Posted by Daniel Halfpenny on 25 April 2008 at 12:01
    Might be a daft question but other than a set of rollers, is there a machine that will apply your application film to your vinyl easier than by hand or has it got to be by hand.
    I struggle with some of the vinyls I cut which are often 2000 – 4000mm length x 600mm wide and its a real pain to ensure they get mounted to application film perfectly ….. surely someone must have invented a machine to aid this process by now.
    Riku Suominen replied 17 years, 7 months ago 5 Members · 6 Replies
  • Dave Bruce
    25 April 2008 at 12:14
    Have a look at the Easy Taper Daniel, there is a link on the front page. (Ok there used to be) just google
    yep its called a laminator
  • Daniel Halfpenny
    25 April 2008 at 12:25
    You guys could be life savers …. I never even thought of using a Laminator … its so obvious when you think about it.
    Joys of being self taught
    Thanks guys
  • John Childs
    25 April 2008 at 13:01
    A laminator does the job admirably.
    But maybe, for occasional use, an ordinary application tape dispenser would be better.
    http://www.jagsignsupplies.com/aqshop/c … php?id=876
  • Daniel Halfpenny
    25 April 2008 at 13:13
    Yes I already have one of these roller things …
    whats your thoughts on the manual laminators that you can get for laminating photography etc.
  • Riku Suominen
    25 April 2008 at 18:43
    First of all, hello from finland to everyone. Few weeks ago i bought this : http://www.biedermanngmbh.com/rolllam/120-160.jpg for applying application tape, i can also use it to laminate with heat. I already got 110cm cold laminator machine which i use with my sp-300v roland to laminate, but i needed that extra width to use full size application tapes.
    Sorry if my english is in rust, first time in ages i have to write it 🙂
    Main purpose for that new 140cm laminator is for applying that application tape, i just thought that when my sp-300v becames too small, the laminator machine works in future with wider machines.
    The reason for buying it was that in future, i´ll have to cut 1-3 full size rolls in a week. Applying that application tape by hand would be suicide.
