Home Forums Sign Making Discussions Vinyl Does anyone know of a product called blackboard vinyl?
  • Does anyone know of a product called blackboard vinyl?
    Posted by Pryam Carter on 14 October 2004 at 10:03
    I’m looking for a solution to painting chalkboards with blkboard paint. I’ve seen one or two products that claim to be easy wipe blk board but they aren’t thaty great to be honest. Does anyone know of a good product for this job?
    Peter Normington replied 21 years, 2 months ago 2 Members · 2 Replies
  • cabriofx
    14 October 2004 at 10:47
    Most vinyl stockists supply chalkboard vinyl which can be applied. I found it works best for all the pub jobs that ive done and great for a-boards. The onyl down side was that it was difficult to wrap round, but the little heat does the job, though will have to be careful as it can detoriate through crackling. Other than that good piece of vinyl to have on the shelf. I know metamark and Allprint are the cheapeast, or ask your suppliers if they do it.
    There is also dry-wipe vinyl too. And you can get special liquid pens that write straight onto the vinyls which could be a good selling point with the job in hand. I’ve now found that my local art shop supply these cheaper, unless someone knows even cheaper. Ive attached a pic of these.
    14 October 2004 at 19:06
    We use blackboard vinyl very often for menu boards on catering vans. We get it from cherwell sign supplies, its made by aslan but there are other makes around. It can be cut in a plotter, I use a 45 degree blade. You will need to do several test cuts because the backing paper is thin and the vinyl thick 😀
