Home Forums Vinyl Cutter Discussions Mimaki Cutters Does anyone have drivers for the following plotters please?
  • Does anyone have drivers for the following plotters please?
    Posted by Vince Francis on 2 February 2006 at 17:20
    Does anyone have drivers for the following:
    Mimaki CG-121 Vinyl Plotter Drivers
    Windows xp op system, to print from Signlab 5
    Or is there another driver that can be used
    Many thanks
    Vince
    Frank Droog replied 19 years, 8 months ago 2 Members · 2 Replies
  • Josh Steenbergen
    19 April 2006 at 15:25
    Got to http://www.mimakiusa.com you can get driver from there in I’m not mistaken..I know this is alittle late, but you will know in the future too..
    Josh Steenbergen
  • Frank Droog
    20 April 2006 at 17:29
    I assume you mean PLOT and not print.
    You should be able to use almost any HPGL based driver including the
    Mimaki pro series driver.
    You might just have to change the Page size in Plotter setup to match the width of your cutter
    PS, make sure the plotter is not set to Center Origin.
    Mimaki had a habit of shipping cutter set to center origin.
    Make sure it is Lower Right on the cutter
    frank at cadlink.
