Home Forums Printing Discussions Mimaki Printers does anybody know where to source rockhopper print heads?
  • does anybody know where to source rockhopper print heads?
    Posted by James Easton on 10 July 2008 at 13:31
    hi i just got one of these and it needs 4 new print heads doe’s anybody know where to source them at a decent price thanks guy’s
    James Easton replied 17 years, 5 months ago 3 Members · 9 Replies
  • 9 Replies
  • Kevin Flowers
    10 July 2008 at 13:48
    i just got a couple of heads from these guys, had no problems but please make your own mind up to use them, i’ve not used them enough to recommend them.
    http://www.digiprint-supplies.com
    10 July 2008 at 14:13
    That’s an interesting website… anyone had any success with them? 300 euro minimum order i see, based in Belgium
  • James Easton
    10 July 2008 at 14:36
    seems expensive wonder if there’s anywhere less costly
  • Kevin Flowers
    10 July 2008 at 14:46
    James
    phone up Mutoh then you’ll get costly, i payed £739.56 for 2 heads, 6 dampers & 6 capping stations delivered to my door. It would have cost me double from Roland. Had no problems with the two heads or dampers not fitted the capping stations yet.
    they don’t understand urgent but other than they SEEM ok to deal with, i payed via credit card to give a little added protection. You can speak to them by phone although i ordered by WWW which may have been the reason for the delay.
  • James Easton
    10 July 2008 at 14:47
    found
    http://www.macmedia.com/
    there about £270 anybody know anywhere else
  • Kevin Flowers
    10 July 2008 at 14:59
    James
    thats in the USA so you can add import tax, carriage & then VAT on to that. If you check through old posts you will see that this discussion has been had many times.
    Also judging by the serial number on the head in the picture they are not genuine parts as Roland don’t use all of the numbers on there heads don’t know about Mutoh or Mimaki. They work i actually have 4 in my Roland did have six but 2 have just blown after just 18 months, hence the 2 new Roland heads i have just fitted.
  • James Easton
    10 July 2008 at 15:28
    thanks really appreciate the help so buying from digi print was everything genuine and working correctly also did you fit the heads yourself
  • Kevin Flowers
    10 July 2008 at 15:53
    James
    as stated parts i have fitted are all fine, i fitted my parts myself but i’m an engineer or Ex engineer & have worked on solvent coding machines in the past so do have some experience. The Roland has a multi part head set up that if you don’t have a manual or know what you are doing you would never get them aligned correctly i would presume the Mutoh to be the same, you will also need access to the service menu don’t know how to access that on a Mutoh. You can also damage expensive heads very quickly if the serial etc are not entered correctly as this is the coding for the crystal inside the head. Obviously don’t know your history but if you ain’t sure it may be worth while getting an engineer to fit them.
  • James Easton
    10 July 2008 at 17:23
    can you find out how to access the service menu that would be really helpful
