Home Forums Sign Making Discussions General Sign Topics Does anybody know of…
  • Does anybody know of…
    Posted by Neil Davey on 29 January 2006 at 16:22
    a supplier of large banner type signs.
    I’m looking for a ‘banner’ about 7 or 14 metres wide to span structural steelwork while it’s going up so it must allow wind thru it otherwise I think it will act like a sail. I don’t want it blowing away. 😳
    Any ideas 😕
    Neil
    jamiet2k replied 19 years, 11 months ago 4 Members · 4 Replies
  • Dorian Marks
    29 January 2006 at 20:43
    we use trade brigade (www.tradebrigade.com) for this,
    great service
  • Nick Williams
    30 January 2006 at 10:44
    i use trounce banner for my banners but dont know if they do the kind of thing you want (www.trounce.co.uk)
    30 January 2006 at 11:47
    are you referring to banner mesh. It is the lastes thing to cover scaffold here, but I think it is best printed not painted, could be wrong tho
  • jamiet2k
    30 January 2006 at 12:25
    If you are looking to span that sort of distance, you will need to use PVC Mesh & it will need heavy reinforcing.
    The safest way to install is to use a heavy duty galvanised steel cable (I would have thought at least 1 inch dia) with a tensioning bolt.
    Have the cable threaded through a sleeve at the top of the banner, and the same again across the bottom. If the banne is being made of more that one piece, you will also need any joins in the banner to run vertically, not horizontally.
    The largest we have mounted was for BP, to go between 2 steel towers at a refinery in Germany. I think it measured 9m (w) x 6m (h).
    Jamie
