Home Forums Software Discussions Adobe Software Does anybody know how to print 60% coverage from Photoshop?
  • Does anybody know how to print 60% coverage from Photoshop?
    Posted by bootyhunter on 11 June 2004 at 07:37
    Hi Folks,
    Got another question…
    The reason is that I need this for using puff inks and the gaps are used to allow the puff to expand without stretching or distorting the garment.
    Trouble is, I have hunted around in Photoshop and can’t find the command anywhere.
    Cheers,
    BootyHunter
    Ian Hatfield replied 21 years, 6 months ago 3 Members · 3 Replies
    11 June 2004 at 08:41
    havent got a clue whot you are doing but you could set the transparancy of the layer to 60% or is it 40% any way just a thought
  • dannymac2020
    14 June 2004 at 09:28
    You could try using the halftone tool under filters (set all the angles to the same number) mess around with the dot size till you get roughly what you need.
  • Ian Hatfield
    30 June 2004 at 08:50
    If you are using a RIP you should be able to restrict the ink limits there.
    Ian
