Home Forums Sign Making Discussions Neon, LED, Lighting do i overlap the vinyl on light-box?
  • do i overlap the vinyl on light-box?
    Posted by Brian Little on 12 April 2006 at 19:33
    hi folks im doing a light box just now Looks like im gona have to do the vynil in 2 sections .Because its a translucent vynil am i better to overlap it slightly ? or just line it up exactly .The reason i ask is that im a bit worried that when the lights on there this dark line .As it is the company want to change the add on it every 2 months or so …so i dont suppose it matters to much .But i want it to look as good as i can
    Regards Brian
    Brian Little replied 19 years, 8 months ago 4 Members · 5 Replies
  • Andy Gorman
    12 April 2006 at 19:39
    I would overlap slightly. Translucent is more stable but may shrink a tiny bit.
  • Brian Little
    12 April 2006 at 20:01
    cheers andy …its a dark blue .How much over lap 5mm?
  • Stephen Ingham
    12 April 2006 at 20:14
    brian, we had a bad experience with overlapping
    we did a print on the versacamm for a menu board and overlapped by about 2-3mm, it stood out like a flashing beacon when the light went on.
    Now if i do a similar job i tell the customer and try to make a feature of the area/ line.
    stephen
    12 April 2006 at 20:19
    brian
    any overlap, as Steven says will show, it will be darker,
    You do need to overlap to allow for shrinking but 1 or 2 mil is plenty between colours,
    but try and avoid tiling, it tends to stick out like a sore thumb
  • Brian Little
    12 April 2006 at 20:25
    Thanks Steve/peter . Thats what i was a bit worried about .as i said they want to be able to replace the add now and again so its a bit of "research & development "with it ….thanks for your imput
