Home Forums Printing Discussions Sublimation Printing discolouration due to heat?? advice please
  • discolouration due to heat?? advice please
    Posted by Hugh Potter on 14 June 2009 at 13:27
    HI all,
    got 20 red polo’s to do for a customer, he wanted cheap so that’s what i got, however, i’ve just gone to throw them into the heat press to remove the moisture -yes, i know it’s sunday!- and as per normal they steam off in about 20-30 seconds (150°c) but, when i remove them there’s a large dark rectangular patch from the platen,
    i seem to recall this happening before with no lasting effects but seeing as this is for someone else and not something i was toying with, i’d rather be safe than sorry,
    also, just noticed some red colouring on the foam pad on the platen base, would i be best to advise the customer to wash all seperately before wearing?
    just curious as to what othr people do!
    cheers,
    Hugh
    Hugh Potter replied 16 years, 5 months ago 8 Members · 12 Replies
  • 12 Replies
  • Gordon Galloway
    14 June 2009 at 15:21
    I would normally only give them about 10 seconds to remove excess moisture, are you putting vinyl on or using transfer paper?
    Gordon
    14 June 2009 at 17:50
    quote Gordon Galloway:
    Gordon
    i was told to press it til all the steam has gone, 10-15 secs @180-200°c but anywhere to 30 secs on 150°c. depending on garment and moisture content.
    gonna press vinyl on.
    i’ve been out to do a job this afternoon (customer will have a surprise in the morning, he was expecting me wed’s!) and left the shirts, the darkened area’s have gone back to normal now, i’ve noticed this on other red items and navy blue too,
    still, seems ok now!
    cheers,
    Hugh
  • Ian Pople
    14 June 2009 at 19:59
    hi,
    Yes the red ones change darker had a shock when I first started with them.
    Ian
  • Mike Grant
    15 June 2009 at 20:50
    This is the first time I have heard of heating the shirts first. Is this really necessary???? Should this be done with every shirt!
    15 June 2009 at 21:25
    quote Mike Grant:
    if you think they are damp. i normally try the first one to see
    apparently if its steaming then the glue don’t stick as well.
    15 June 2009 at 22:55
    i do it because i was advised to, think the magic touch videos mentioned it.
    the reflective definitely has problems sticking if damp, the steam affects the glue,
    16 June 2009 at 07:20
    I always prepres as well but only for about 10 seconds at most. Several instruction sheets I’ve seen from different manufacturers have advised the same. First time I pressed a red shirt I had the same shock.
    Alan D
    16 June 2009 at 07:26
    not just me then, that’s good!!
  • Mike Grant
    16 June 2009 at 21:35
    Thanks guys, I’ll remember that. 😀
  • Alan Nisbet
    17 June 2009 at 17:32
    I started pre-pressing t-shirts to get rid of the creases, especially on cheaper t-shirts, this habit stayed with me and also was found out about moisture after a the first few months of pressing. The colour change is normal but goes back to normal when cooled down.
  • Matt Hards
    18 June 2009 at 17:16
    ive had same shock too lol
    18 June 2009 at 18:21
    i can see Matt,
    it’s made your hair stand on end!!
