Home Forums Sign Making Discussions General Sign Topics disaster cutting
  • disaster cutting
    Posted by onestopsigns on 27 April 2005 at 17:36
    hi i cut 3 dragons today
    1 meter long 45 high
    all 3 were cut put then cut through it self
    i really have no idea wats wrong
    ive welded it as well and still does it it is a fault with picture ?or machine??
    its in swap section for me all i did was open in corel and export as eps open in artcut then cut
    then i welded it and cut
    then i welded again twice and cut
    wasted 4 meters of vinyl today alone on this
    any help greatly appreciated
    onestopsigns replied 20 years, 8 months ago 7 Members · 11 Replies
  • 11 Replies
  • Richard Urquhart
    27 April 2005 at 18:25
    can you not post the file up on the boards and we can have a look at it i know in flexi which i use it you highlight the image it will show where cuts are befor you send to cutter post it up and if i cant help someone will
    rich
  • Dave Ward
    27 April 2005 at 19:01
    HI onestop what operating system are you running on your pc is it xp ? if so it could be that you need to set/reset the port the cutter is using.
    27 April 2005 at 20:56
    When you view the vector without fill or as an outline can you see what you should get?
    27 April 2005 at 21:22
    coral when importing some ai or eps files will have a spurious line which is a broken loop joined in the wrong place and will do exactly as you describe. also if the plotter is driven via the serial connector the wrong handshaking or poor connection in the cable will also do as described – all from experience of this
    Chris
  • Dave Ward
    27 April 2005 at 21:31
    Try this go control panel and the printer folder click on file then choose server properties, click on the port the cutter is using(mines on com 1 serial port) then click configure port, then click flow control and choose xon/off then apply.
  • onestopsigns
    27 April 2005 at 22:17
    hi thanks for all responces will post it up tommorrow as i left it in shop in disgust lol
    i am on windows xp
    i am set as x on x off
    it is an outline and it does show up as it should do
    ive had a few of these a si poiste dbefore and was told to weld which sorted it but its not sorting this one lol
    mr sticker sounds like ur veiws might be the right thing how would i solve it
    its an ai image which i saved to pc from here in the swaps sections of the dragon made for me with 4 legs
    then i impoted to corel 11 then exported to eps for me to import in to artcut
    is there any cutters that just cut from ai ? or is that un heard of .
  • Gordon Forbes
    27 April 2005 at 23:59
    No you can cut fron illustrator but you have to make a new pallete colour and name it Contour Cut or some thing like that I got a how to from the Roland site but never needed it as I use signlab which is very good for cutting.
    Goop.
  • Dave Bruce
    28 April 2005 at 07:41
    I get this when importing images from other packages. If the separate parts of the image are not overlapping then welding does not solve the problem. You need to move the nodes of one section over the next section then weld, if it is the same colour then you may be left with a small section where the overlap was, remove this and the object then just has the outline to cut.
    Hope this helps
  • onestopsigns
    28 April 2005 at 08:20
    but ok then why does this cut buetifully at 30 cm long yet wont at 1 meter long
    sure the same mistakes would be on the smaller as is on the bigger one
    28 April 2005 at 08:54
    there was a drag.ai dragon file on here the other day with 3 dragons in the file the top and middle ones have a loop fault and was caused by 2 nodes to close together – top one buy its eye middle one half way through its tail – why should it cut OK smaller ?.
    as i remember the port should be set to hardware control its years since i had a serial plotter this problem will only show up on bigger stuff as the buffer handshakes when its full
    Chris
  • onestopsigns
    28 April 2005 at 17:06
    the 3 dragons are the one im talking about except they had 5 legs and a kind gentle man here posted one with 4 legs this is the one ive been useing
    the fault was caused near its tail first time and tounge second time
    today i cut it a metwer long with flexi sign 7.5 and it cut perfectly
    yet in artcut it dont
    i need this bigger 1.5 meters to 2 meters long so will play with flex sign tommorrow as ive never used it till today as like artcuts simplicity
    as for memory handshakes ect
    is this memory in plotter orin pc ? if pc more memory will help yes?
