Home › Forums › Sign Making Discussions › General Sign Topics › Direction Sign question
Posted by Jeremy Howes on 16 June 2007 at 03:17Hello,
As a general rule when making directional signs with text and arrows, do you centre the text or centre the text and arrow?I hope this makes sense.
JeremyDavid Rogers replied 18 years, 6 months ago 6 Members · 6 Replies -
I don’t really understand the question to be honest 😳 but I centre everything. If the text is on the same line, I combine it and then centre it, If the arrow is under the text, I centre everything under each other.
Do you have a pic as an example to what you refer?
Thanks Shane,
The arrow is in line with the text so without fully understanding the question you managed the answer.Many thanks
Jeremy -
for me it depends on whether the text is upper or lowercase….I would always centre the arrow but if the word has decenders I would centre it by eye so it looked right rather than automatically
if it is a sign with multiple directions ie. some to the left and some to the right then I would centre the text. If it is one locatation and and arrow then I would centre the text and the arrow, but you need to put the arrow a little further over to the edge because the point creates an optical illusion and it looks off centre, you will see what I mean when you set it up with a box around the text.
I tend to centre justify the longest one (text & arrow) – and then all subsequent ones keep any arrows and the start of any text in that same position for a uniform appearance. Stops a random margin from spoiling any signs that are stacked or in close proximity.
Vertical alignment is usually as per vertical centre of the upper case.
