Digital wallpaper application. Advice needed please?
Hi folks
I presume that when printing digital wallpaper that you would leave an overlap between adjacent sheets, is this correct? …. surely you couldn’t easily cut accurately enough to give edges that but up against each other exactly?
So if applying digital wallpapers (glued up not self adhesive) with say a 10mm overlap would you then knife between the overlap to leave flush joints or simply leave the overlap on the finished job?
I am also thinking of the issue with regard to mailing digi wallpapers out to customers, what would you advise them to do?
Thanks in anticipation…
