Home Forums Sign Making Discussions General Sign Topics Dibond to fit arch help…
  • Dibond to fit arch help…
    Posted by Nathan on 17 February 2006 at 18:23
    Does anybody know of a company that will cut dibond to shape. I need to fit a fascia into an arch above a shop, the widest point is 20ft and the highest point is 4ft.
    Nathan
    Peter Normington replied 19 years, 10 months ago 2 Members · 5 Replies
    17 February 2006 at 18:29
    natham
    I think amari in bedford have a sub contractor who does it for them.
    but I would say the hardest part would be drawing the shape for them.
    By the time you have done that, you are only one step away from doing it yourself with a jigsaw,
  • Nathan
    17 February 2006 at 19:07
    Peter – I was planning to get a square on photo and create the shape from that but I’m not sure if that would be the correct method. If I was to cut it myself I’d be unsure how I’d transfer the shape template to the substrate as I only have a 24″ cutter.
    Nathan
    17 February 2006 at 19:22
    Natham, I doubt if a photo will be accurate enough, Does the arch have a constant radius, or is it flatter In the middle?
    You may have to cut on site to get a good fit. Or maybe you could mark out a template in cardboard or hardboard?. Is the dibond to be monuted onto an existing flat surface or is it to “fill in” the arch.
  • Nathan
    17 February 2006 at 19:44
    Peter – I think making a template out of cardboard would be my best option, the dibond is to fill the arch in.
    Nathan
    17 February 2006 at 19:46
    Sorry NathaN
    I just had my front teeth redone and I have a LISP
