Home › Forums › Sign Making Discussions › Vinyl › diamond grade cutting query needed please?
Posted by Brian Little on 24 May 2005 at 15:12before i waste me money !!!…is it possible to cut diamond grade with an ordenary plotter …with the rite blade ?
Regards brian 😀
Brian Little replied 20 years, 6 months ago 5 Members · 6 Replies -
I wouldn’t think so it’s very thick stuff.
might be wrong tho it’s a couple years since I used any, cut it with a knife then.
Neil
i no theres differnt blades for the plotter neil….but this one simply doesnt cut it (excuse the pun)
Regards Brian
I know cutting ordinary reflective ruins your blade so I imagine diamond grade the blade won’t even touch it unless you put the pressure up and maybe wind the blade tip down a bit may work don’t know but if it’s just squares or stripes can you not cut them by hand ?
Don’t think you’ll cut it with any normal roll fed plotter Brian. I think you can cut it on heavy duty flat bed machines but I’d not risk knackering your plotter if i were you !
Nigel
You’ll never kiss cut it with a ‘normal’ plotter. The only possibility is to cut on the reverse (creating a score line) and snap out. Even still, you’d probably have to do a few passes. Also, it curls like a bugger and is almost impossible to keep flat on any plotter other than a flat bed with a vacuum hold down bed.
well ill Take your advice Nigel and not bother …..it was just a thought .The customer had seen the police traffic cars and asked what it was . But he can make do with ordinary reflective .its just a few lines of lettering on transit
Regards Brian
