Home Forums Sign Making Discussions Vinyl DG Media Profiles For Roland Versaworks
  • DG Media Profiles For Roland Versaworks
    Posted by Christian Davies on 24 November 2018 at 14:22
    Hi, we have purchased some DG printable vinyl from MDP supplies. Do you know where we can download DG media profiles for use in Roland versaworks? Or do you know what media profiles can be used on DG media? Thank you.
    David Stevenson replied 7 years ago 6 Members · 8 Replies
  • 8 Replies
  • Jonathan feeney
    24 November 2018 at 17:37
    quote Christian Davies:
    Is it the dg cal stuff ?you could try their website ?not mdp the dgcal website
  • Christian Davies
    24 November 2018 at 17:43
    Yes it’s DG Cal
  • Christian Davies
    24 November 2018 at 17:52
    I could not find any profiles in their website
  • Jonathan feeney
    24 November 2018 at 17:59
    Maybe contact mdp head office in wirral
    25 November 2018 at 18:35
    If in doubt use the metamark MD5 profile 😉
    25 November 2018 at 19:20
    keeping it simple, if its white and printable then one of the generic profiles should be fine if it thicker or thinner than standard then you may need to adjust the feed, advantage is more consistent colours when moving from stickers to banners etc.
    ducks for cover
  • Chris Wilson
    25 November 2018 at 21:44
    We use generic profile number 2 for DG cal monomeric which we have tried. Actually quite like there clear film. It’s just that little bit thicker than most and nicer to apply I find.
  • David Stevenson
    26 November 2018 at 10:15
    As mentioned by David, give Md5 a go. We use it for almost everything with great results
