Home Forums Software Discussions Flexi Sign Software Design Central boarder – can I remove it?
  • Design Central boarder – can I remove it?
    Posted by Diane O Connor on 3 September 2014 at 06:54
    When I open a new page the design central box outline is always there. Can I get rid of it – I find it really frustrating and prefer to insert my own sign substrate background for each job.
    Liam Pattison replied 11 years, 2 months ago 2 Members · 3 Replies
  • Liam Pattison
    3 September 2014 at 11:02
    If i don’t want to see the page outline i just make the working page much bigger than i need within design central and then insert the sign substrate, or draw a substrate within that.
    The outline you see is just the edge of the page, you can make the page as big as you like.
    If you type ctlr + 5 together whilst your substrate is selected you will center it within your workspace.
    Or, if you are working on a square or rectangle you can make the page outline the same size as your substrate then surely you wont see the page outline will you?
    Unless i misunderstood.
    Liam
  • Diane O Connor
    3 September 2014 at 11:08
    Many thanks. I had a further dig around and discover you can ‘remove’ boarder in Design Central so in effect you don’t see it.
  • Liam Pattison
    3 September 2014 at 11:10
    I didn’t even realise you could do that. Just checked and saw it’s next to the page size.
