• Posted by Harry Cleary on 10 January 2009 at 22:32
    Just been reading Mike Grants post about disappearing technology…..an I hope this may help some of you Late last year my laptop fell, resulting in a dead hard drive, I tried everything to access the data( and I mean everything, even freezing it in the freezer!) I had almost given up on it when I discovered this page http://www.help2go.com/Tutorials/Comput … puter.html and followed the instructions to the letter. Inserted the disc with Knoppix burned on to it and BINGO….was able to access the dead drive and copy the files across to an external drive. May not help everyone affected but it is worth a try. I have just finished rescuing all my music gathered over three years….I am as happy as a pig in the proverbial!! 😀
    Justin Mann replied 16 years, 10 months ago 7 Members · 14 Replies
  • 14 Replies
    10 January 2009 at 22:38
    that does look good… might have to test that software out
    good find Harry. 🙂
    Shame you managed to rescue your music though …….. would have thought it might be a relief to lose Bjork!!!!!!!! 😮 😉
    10 January 2009 at 22:40
    or that other music festival website harry has 😉
  • Harry Cleary
    10 January 2009 at 22:41
    quote Marcella:
    good find Harry. 🙂
    To each his own!! (hot) (hot)
    11 January 2009 at 12:23
    cool, i have 2 dead drives here with around 4yrs of the kids growing up still stuck on them, will have to take a look at that!
  • Stephen Ingham
    12 January 2009 at 09:23
    hi all, this has been an issue for me for some time….
    can anyone advise on how to retrieve info from a drive that will not "fire up".
    we have a drive that was used as an external drive to back up onto, however came to back up one day and the drive just wont work, the hard drive doesnt seem to spin/ activate.
    any ideas how we can get the files off of it?
    any help or advice would be appreciated.
    stephen
    12 January 2009 at 09:38
    Stephen, in your case its a harddrive rebuild by a specialist. Needs to have the same model and then they will transfer the innards to it in a clean room situation.
  • Harry Cleary
    Have an external drive here as well that I haven’t had time to try but I would be confident the Knoppix software will retrieve it, it sees any drive connected to the computer. Worth a go, software takes a good while to download.
    BTW, the software seems to default to German, I found that when you are asked to boot it, if you type ‘knoppix lang=US it will boot in english.
  • Tim Painter
    12 January 2009 at 10:39
    Stephan have you removed the drive from it’s case?
    You say that it’s an external drive just wondered if you have only tried connecting it as USB or whatever interface it is.
    Tim.
  • Stephen Ingham
    12 January 2009 at 10:42
    hi tim, it is a hard drive mounted into an external drive case that connects through usb.
    when w plug it in nothing happens, yet if we take it out and stick another in its place the new one works fine, so its not the external casing, its definately the drive not "firing up"
    stephen
  • Justin Mann
    12 January 2009 at 14:32
    A couple of years ago I managed to mess up a drive with years of information on it, yes I had a backup and I’m ashamed to say I messed that up at the same time!
    Anyway, I started hunting for recovery software, found many expensive programs, even spoke to a company who quoted me around £3k to recover a possible 95% of the data! After trying a few trial programs I came across a decent one, bought the full version for £50 and recovered 99% of the data on a formatted drive, brilliant bit of software. At the time it renamed everything, 1000’s of files were given a number for a file name so I had to manually sort them, took weeks. The software has since been updated and now puts everything in a tree structure using original file names.
    I’ve used it on several occasions to help other folk out, even retrieving photo’s lost on a formatted compact flash drive.
    Embarrassingly I can’t remember the name of the software so I’ll take a look when I get home and re-post if anyone’s interested.
    Cheers,
    Justin
  • Justin Mann
    12 January 2009 at 14:39
    Hehe, I just remembered the name……
    Easeus Data Recovery Software.
    Justin 😉
  • Stephen Ingham
    12 January 2009 at 15:01
    hi, but that would only work on a hard drive that spins/ fires up….. mine does nothing at all…
    stephen
  • Justin Mann
    12 January 2009 at 15:03
    Jump leads?
