Home Forums Printing Discussions Uniform Printers Cutting wrong size
  • Cutting wrong size
    Posted by M Brown on 4 March 2009 at 16:11
    Hi All,
    I have a 54" Grenadier print and cut printer. I had a customer wanting just 6off black vinyl blocks of vinyl cut to size, an accurate size of 2200mm x 660mm. I cut one to check the size and it cut 2203mm 661.5mm.
    Is there a way I can adjust my machine to cut the correct size. This is not the first job that I’ve noticed that its not cutting the correct size.
    I had to cut all 6 by hand to make sure that they were cut at the correct size.
    Oh yea, whats happening to B&P?
    From Mark
    Jon Marshall replied 16 years, 10 months ago 4 Members · 4 Replies
    4 March 2009 at 16:39
    surprised its out across the plotter might want a environment check. i don’t think there is any adjustment across but there is in the feed direction.
    in the menu is calibration. unfortunately i get brain fade when trying to work out the % difference. so over to the others.
    its not uncommon for these to be out just people don’t notice
  • John Thomson
    4 March 2009 at 16:40
    Sounds like it needs calibrated?
    I’m sure someone cleverer than me will be able to tell you how to do this 😀
  • Glenn Sharp
    4 March 2009 at 16:44
    In the menu there is a cut calibration test…..it prints and cuts a grid and you can then fine adjust it from there in the menu
  • Jon Marshall
    4 March 2009 at 17:11
    quote M Brown:
    Hi All,
    From Mark
    They are in administration.
