Home › Forums › Sign Making Discussions › Vinyl › Cutting vinyl from plotter
Posted by Daniel Warren on 20 February 2012 at 18:53What do people use to cut their work from their plotter?
I have been using scissors, but it doesn’t give a neat finish. I don’t fancy running a blade against the machine itself to cut through.
I think this sort of knife could be useful, just wondered what people felt comfortable to use for one man operation.
Daniel Warren replied 13 years, 8 months ago 10 Members · 12 Replies -
There are actually several slots which may have been added for that purpose :lol1: I just would rather not deface it.
Hopefully Sign UK will be giving away some of those Krispy Kreme doughnuts (hot)
Don’t know how you would deface the plotter using them Daniel. That’s what they are for, good sharp blade, no bother.
p.s. it’s not the doughnuts you have to worry about at SignUk!!! 😀
I use a snitty cutter or similar to cut from my plotter. Just feed off around 120mm after cutting and job done.
There’s a groove on nearly all plotters specifically for cutting in. Either with a ‘snitty’ or just a knife.
It’s not really defacing – it’s using.
ive got one of those blue cutters like Harry, from Grafityp, its also great for chopping vinyl off a roll
Daniel
I know what you mean. I have a Summa D-60 that someone used a razor blade on and scratched up the surface.
Summa sends a Couppy Cutter with their D-60 but the previous owner didn’t use it.
Here is a link to the Couppy Cutter http://www.martor.comcouppy_43136.html
Mine even says Summa on it.
we just use envelope openers from staples. £3 for 2 approx
I usually get a couple of freebie cutters at Signuk …..I run them along a groove for a nice straight cut.
I suppose it really is function over form and scratches aren’t worth worrying about,, I’m just anal about that sort of thing. I’m that guy that when I take an electrical item out of the box I keep every plastic sleeve and padding incase I ever need to return it. I need to get a grip :lol1:
