🙁 i am trying to cut 10 mm high fonts ,but the start /stop points dont seem to be joining (there is a small uncut area)has any body got any solutions,ie – cutter setup or tweeks to corel setup, i am using corel draw and a dingtec cutter,thanks rob
Robert.
Its probably the blade offset.
Is the blade old? If so replace with a new one and set the offset to factory default for the blade.
The offset can be adjusted on most plotters, but for small letters, its probably best to just renew if the blade is worn. Also check to see if the blade is free to rotate in the holder.
If you to know more about offset, try a search off the boards its been covered in detail quite a lot.
Please note:
