Home Forums Sign Making Discussions General Sign Topics Cutting round door handles. Cut on vehicle or template?
  • Cutting round door handles. Cut on vehicle or template?
    Posted by JonPinder on 24 April 2012 at 20:37
    Hi all,
    Looking for some wisdom on fitting some Tommi Makinen stripes on an evo. When it comes to trimming round the door handles and fuel cap, would you do this on the vehicle or make a template and cut off the vehicle, the type of strips are identical to the one on the link below
    http://forums.jdmvip.com/Mitsubishi_Lan … ars-3938-t
    The customers has already bought "a kit" which I’ve seen and it doesn’t have them already cut out like the actual official stripes do.
    Any tips and tricks greatly appreciated.
    Jon
    JonPinder replied 13 years, 8 months ago 6 Members · 7 Replies
  • 7 Replies
  • Reza Faezi
    25 April 2012 at 16:22
    I HATE trimming on vehicles, but sometimes it just has to be done. Tried a few different ways but on a recent vehicle wrapping course, we were urged NEVER to trim on the vehicle and to put a bit of masking tape along where you need to trim and to trim on the masking tape, then after trimming pull the bit of masking tape out from behind the vinyl and apply whats left unstuck. Another reason is a customer came to us today to replicate what he currently had on this van. Upon closer inspection, some of the graphics had been trimmed on the van and you couldnt half tell!!! Where every piece of vinyl had been trimmed, there were nice big rust marks!!!! After seeing this i will not ever be trimming on any vehicle ever again!!!!! Hope this helps
  • George Zerbino
    25 April 2012 at 17:32
    I’ve fitted loads of these actual ones for a local importer, always used the original graphics which are indeed cut around the handles.
    If I had to make them I would make a template on the car and then cut them to the right shapes, this way you’ll get a perfect fit.
  • Mark Nihotte
    25 April 2012 at 20:12
    Hi Jon
    Have been cutting on the vehicle for years – make sure your blade is wet (lick it) and lightly drag (don’t press) freshly snapped blade…have a few practices and you will be surprised how easy it is.
    Otherwise there is knifeless tape ( http://knifelesstechsystems.com/Products.aspx ) which we have been using for a short time – it works extremely well for long cuts and the easy way to make the perfect overlap 😀 😀
  • Cheryl Smith
    26 April 2012 at 07:09
    quote Mark Nihotte:
    Hi Jon
    surprised you still have a tongue Mark!!! 😕 😕
  • Mark Nihotte
    26 April 2012 at 09:59
    Sometimes you just have to live dangerously 😕 😳
  • Glen Mathers
    26 April 2012 at 13:18
    I always cut on the vehicle but i make sure i always use a fresh scalpel blade. I never tried licking it though 😀
  • JonPinder
    29 April 2012 at 14:13
    Hi everyone,
    Thanks for the replies, I’ve only just seen them as I didn’t get the email notifications for replies. I made a template in the end stuck it to the vehicle then ran the vinyl over the top taped it to the template then removed and cut off the vehicle. Then fitted the graphic, this method proved time consuming but got the job done.
    I’ll be testing out some of the suggestions on here ready for next time.
    Thanks again, really appreciate it. 🙂
