• cutting problems
    Posted by nick cope on 27 February 2007 at 17:06
    can anybody help me
    when cutting out my letters ,the blade is leaving a line where is cuts across the vinyl to startcutting the other letter ,and also it dosnt seem to be finishing of the letters ,on the odd letter in the word ,iam using winpcsign design programe, can anybody help me out , is it to do with blade offsets or , pressure i dont know
    thanks
    shizzle replied 18 years, 7 months ago 5 Members · 5 Replies
    27 February 2007 at 17:11
    No it probably doesn’t have anything to do with either of these but the blade may be set to low in the holder, don’t know your set-up so can’t advise how to alter it. It could also be down to the cutting strip not sitting flush on the plotter, the rollers not being positioned correctly allowing the vinyl to lift a little in the middle.
  • Lorraine Clinch
    28 February 2007 at 00:56
    You may need a new blade holder? I believe that if the bearing(?) inside goes this stops the blade swivelling properly?
    There has been mention somewhere here of being able to oil it to get it working properly again, but don’t take my word for it, I may be talking a load of rubbish!
  • Andy Gorman
    28 February 2007 at 01:03
    Is the line between letters just a scratch or a proper cut? Know what I mean? It does sound like a problem with the blade holder assembly, assuming you haven’t got the pressure set at a ridiculously high level.
    You can tell by the sound whether the plotter is deliberately dropping the blade or if it is just falling due to a knackered holder.
  • nick cope
    2 March 2007 at 17:31
    thanks for everyones advise,
    the blades not cutting the vinyl when its moving to another point just leaving a faint line, and its strange that it only seems to happen when iam cutting smaller letters , because if the letters are say , more than 5cm big
    then it seems fine, its alot harder than i thought ,but iam sure ill overcome it, best play a tune on my guitar
  • shizzle
    1 June 2007 at 10:38
    quote nick cope:
    can anybody help me
    thanks
    Hi ive had exactly the same problems how did you solve it?
