Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Cutting out wrong size and orientation
  • Cutting out wrong size and orientation
    Posted by Jason Middleton on 3 May 2010 at 21:43
    After finally getting cutting master 2 to launch with Corel X4, when I send the jobs to cut its cutting them out tiny and the wrong orientation and not as they are showing in the preview window in CM2, what am I doing wrong.
    I’ve got the media setting as user defined and job size set to 100%, I’ve tried with the cut position in the centre of the paper, and edge but makes no difference cutter just starts cut from top corner of the paper.
    thanks
    Jason Middleton replied 15 years, 8 months ago 2 Members · 4 Replies
    3 May 2010 at 21:51
    the step command in cm2 does not match the plotter settings.
    as i don’t use cm can’t remember the nos, trying to start it up now
  • Jason Middleton
    3 May 2010 at 22:10
    Thanks Chris googled step command and that’s sorted the size out spot on, the orientation is still not right though, any ideas what that could be
    thanks
    3 May 2010 at 23:10
    good.
    you may have rotate on – on the cutter menu
  • Jason Middleton
    4 May 2010 at 23:01
    Thanks very much Chris, you were correct again, now that’s 2 pints I owe you
    Jason
