Home Forums Vinyl Cutter Discussions Summa Cutters Cutting Issues Summad60/u with flexi 8.1
  • Cutting Issues Summad60/u with flexi 8.1
    Posted by Ernie Falzon on 21 October 2010 at 14:32
    I have a summad60 using flex 8, my summa has just started missing the first bit of the cut on every job. eg if cutting a circle about the first 3or4mm of the cut is missing it’s as though the X and Y runs faster than the blade before coming down to meet the vinyl. 😥 😥 😥 😥
    Ernie Falzon replied 15 years ago 2 Members · 2 Replies
  • SumRandi
    30 November 2010 at 09:39
    Hi there,
    how old is the unit. If it’s an older unit it can be that the holder which goes up and down sticks to the coil and needs a while to get "unstuck". Just needs a replacement bumper piece. If it’s something else it is best to call the dealer.
  • Ernie Falzon
    27 December 2010 at 18:48
    Thanks for the reply, after about a week I had another problem "no power", what a pain this is becoming so I bought a new plotter just so my work does not fall behind.
    I am really pleased with the new summa and pleased with the price since my other summa lasted 8 years with no probs.
    Rather than bin the old one I thought I’d have ago repairing it myself.
    Now i was able to source a new power supply from the UK by reading the model number on the supply unit spoke to the retailer and was assured that this was the correct supply unit. About a week later supply unit arrives checked it against the old one exact match, fitted it and hey presto it worked by doing this I had managed to save about 500 quid.
    So here we go lets test it, fed the vinyl through lowered down the pinch rollers and away it went. The noise coming form the plotter was a knocking as if something fell of the machine, cutting squares was great but anything with a curve you can forget it. Took the machine apart checked all the bearings, belts screws bolts anything that moved. All looked good put it back together.
    I thought maybe the problem would magically disappear "no such luck" so what do I do, flogit for spares or repairs or if there is any body out there who had the same problem please let me know how you solved it. I have attached a vid just so you can see it in action. Thanks all
