• Cutting foamex
    Posted by neilsullivan on 15 March 2006 at 21:46
    I am a bit of a novice, and I am seeking advice on cutting foamex board. The old Stanley knife and metal rule does not seem the best method. Do you guys use any special tools?
    Neil
    Peter Normington replied 19 years, 9 months ago 2 Members · 2 Replies
  • David Rogers
    15 March 2006 at 22:30
    Besides buying it in cut-to-size or having your own table saw / wall saw / varga. A scalpel & straight edge works fine for cutting up the odd section without resorting to making loads of dust.
    Just score the line with the scalpel and straight edge and either place something under the area or hang it off a bench & apply a slight downward force whilst running the blade along (to open up the cut). Through 3mm in 3 passes, 5mm in 3 or 4. Not perfect edges, but OK for most applications.
    15 March 2006 at 22:37
    try a practik keen cut, it uses a stanley blade and for foamex, its fine.
    Saws are a no no, to much dust
    try a google,
    or call them 01536 261 690
    They are in corby
