Home Forums Sign Making Discussions General Sign Topics cutting curves in diabond.
  • cutting curves in diabond.
    Posted by Adam Triggs on 5 July 2007 at 11:07
    Hi All,
    I have a client who wants to replace an old sign. The frame is OK but the ali board they used is knackered.
    What’s the best way to cut a curve shape in diabond.
    It has to be a copy to fit the frame. I have the old sign as a template.
    Adam
    Adam Triggs replied 18 years, 5 months ago 4 Members · 6 Replies
  • Andy Gorman
    5 July 2007 at 11:26
    Jigsaw with a metal cutting blade (fine toothed). Protect the area to prevent the jigsaw scratching, though. If it’s going in a frame the cut doesn’t even need to be perfect, but if you want a perfect cut run some 3-in-1 oil or washing up liquid along the line before cutting. It lubricates and gives a perfect edge.
  • Gavin MacMillan
    5 July 2007 at 12:09
    As Andy sais, although we don’t use any oil or anything. App tape is perfect for protecting it and also a ‘sure form’ is great for taking out any wonky bits!
    G
  • Adam Triggs
    5 July 2007 at 13:05
    cheers fellas.
    I’ll let you know how I get on.
    Adam
  • Andy Gorman
    5 July 2007 at 13:37
    Hmmm yes, the oil is a habit of mine since the days when I used to have to cut aluminium and Perspex lettering by hand! Probably overkill really.
  • Kevin Flowers
    5 July 2007 at 21:13
    Adam
    if you have the original as a template, use a hand router & a small bearing
    straight bit.
  • Adam Triggs
    9 July 2007 at 12:06
    Hss jigsaw bit and oil worked a treat and looks splinter free to boot.
    Cheers All.
    Adam
