Home Forums Printing Discussions Roland Printers Cutting alignment
  • Cutting alignment
    Posted by John Wilson on 25 September 2008 at 21:51
    Think that’s the best way to describe it :lol1:
    Right I’ll use square as an example as it’s easier to explain
    If I print a square and then cut that square once it’s been printed I end up with a white line down one side as if the cutting is off….. it’s only a mm but still a nightmare on text and certain images
    I’ll take a pic in the morning to explain this better but if anyone knows what I mean then do you know a fix to this (?)
    Gary Birch replied 17 years, 3 months ago 4 Members · 8 Replies
  • 8 Replies
  • John Wilson
    25 September 2008 at 21:52
    Ment to say…….. Roland SP300V 😎
    25 September 2008 at 21:55
    on the opposite side to the white line has it cut through the print by the same amount
  • John Wilson
    25 September 2008 at 22:00
    quote Chris Wool:
    Good point but I don’t think so…. I’ll double check in the morning but as I said I don’t think so
  • John Wilson
    25 September 2008 at 22:01
    also it’s with everything that i create or that versaworks puts a image boundary so it’s not down to me doing it wrong 👿
    25 September 2008 at 22:05
    if it was cutting ok do a environment check before doing anything else.
    25 September 2008 at 22:08
    I know what you mean John – it’s a common problem with the versacam and Cadet printers. The problems is worse the smaller the images being cut.
    The answer is to introduce a "bleed" to all your graphics being cut. i.e outline the cutline by a mm or so to ensure the cut path is within the printed area
  • John Wilson
    25 September 2008 at 22:23
    quote Chris Wool:
    i always do that before I print anything
  • Gary Birch
    26 September 2008 at 07:24
    I`m with Phil on this. For all critical work I use a bleed.
    I do long runs of printed stickers which aren`t so critical and over the day it can lose some of its accuracly so much so I end up reloading the media and doing an AUTO Print and Cut alignment.
    But on the good stuff use a bleed.
    Gary
