Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Cutting a smooth line
  • Cutting a smooth line
    Posted by Kyle Bennett on 24 November 2009 at 07:27
    My Graphtec doesn’t appear to be able to cut a smooth line, it keeps leaving little notches where each bézier point would be in the drawings.
    Makes weeding small letters absolute hell!
    CE3000-120, any ideas?
    Kyle Bennett replied 16 years, 1 month ago 3 Members · 3 Replies
    24 November 2009 at 07:33
    Kyle
    Check if the blade is rotating freely in the holder.
    24 November 2009 at 08:23
    Is the item you are cutting a continuous shape with bezier or is it imported from something else and the curves are actually hundreds of straight lines.
    Alan D
  • Kyle Bennett
    24 November 2009 at 08:34
    Good point on the blade rotation, will give it a check
    It’s definitely being cut from Bézier curves directly from Illustrator, I’ve already tested the problem being on the points/nodes by drawing 2 circles, one a standard 4 node, and one with extra nodes placed and it just notches on each node
