• Cutting 4 times?
    Posted by Glen Mathers on 13 June 2006 at 18:51
    Anybody know why my cutter has just started to cut vinyl 4 times in 1 go, it keeps going back and forth over the vinyl 4 times.
    It has never done this before. I have a P-cut 630 and using Signgo but i have tried Flexi 7 and that does the same.
    Any Ideas?
    Glen Mathers replied 19 years, 5 months ago 4 Members · 5 Replies
  • David White
    13 June 2006 at 18:53
    All I can think is your image has multi layers to it might be worth turning it into wireframe and look
  • Tim Shaw
    13 June 2006 at 18:55
    If it is doing th esmae thing in two different programs and only with the same file it sound like you a mutiple copies on top of each other, so the cut is in effect cut four designs, the same , in the same place.
    If it was just in Flexi i would guess the over cut option is set at four. This option is for cutting thick materials, the knife goes round each object the set number of times.
  • Glen Mathers
    13 June 2006 at 19:10
    Cheers Tim, i’ll check in the morning the muliple copies, that sounds a good place to start.
    I’ll let you know how i get on 😀
    13 June 2006 at 19:12
    it sounds like multiple layers to me as well don’t know your programmes but wire frame show fill should give you a clue !!
  • Glen Mathers
    13 June 2006 at 19:29
    Thanks Dave, Tim and Lynn for your help, i’ll give it a looksy in the morning.
    Thanks again, i don’t know what i’d do without you. 😀
