• Cutter Problem
    Posted by LeeMorris on 27 January 2007 at 11:07
    I had this problem before but can’t remember how i fixed it.
    The cutting tool is moving really slow when doing curves, its ok on straight lines
    Anybody know?
    Lee
    Rod Young replied 18 years, 11 months ago 5 Members · 8 Replies
  • 8 Replies
    27 January 2007 at 11:21
    All curves lee, or just certain ones, you may have changed the speed or quality of the cut , both will have an effect. the speed is also affected by the number of nodes in the drawing, so whilst a straight line may have only one node at each end, a curve may have many.
  • LeeMorris
    27 January 2007 at 23:05
    It is all curves
    I have changed the port it was on the wrong one
    Now i have the off scale problem i had before
    Lee
  • Ade Ward
    28 January 2007 at 10:32
    what plotter is it lee?
  • LeeMorris
    28 January 2007 at 10:36
    Graphtec 610mm
    I did have this before and had to ring sign Master Systems but can’t remember what i did to fix it
    Lee
  • Karl Williams
    28 January 2007 at 10:55
    What software mate?
  • LeeMorris
    28 January 2007 at 23:26
    Hi Karl
    Its signlab
    Lee
  • Karl Williams
    28 January 2007 at 23:34
    Hi Lee,
    If you go to cutter setup you will find Arc smooth or curve smooth. If its on turn ot off. There is if memory serves me right a setting for the tool ie: drag knife – pounce – tangelical knife. you need to be on drag knife.
    This works on my summa d610 but not on my summs s class 120.
    Ive got Signlab, flexi and coral. found coral easier to use.
  • Rod Young
    29 January 2007 at 19:47
    quote leemorris:
    • The cutting tool is moving really slow when doing curves, its ok on straight lines
    • It is all curves
    Sounds like an inordinate number of nodes being used to define the curves. However that occured, you want to fix it by going Arrange menu >> Convert to Polyarc, and follow this up with Arrange menu >> Reduce Nodes.
    Regards,
    Rod at CADlink
