Home › Forums › Vinyl Cutter Discussions › General Cutter topics › Cutter plugin for Illustrator?
Posted by Ray on 9 May 2004 at 12:24Hi Guys,
I love Illustrator 10 and the more I use it the more it endears itself to me. Trouble is it has no way of talking to my cutter (GCC Puma). Instead I have to export to the ckunky Signpal Apprentice software that came with the cutter. This works, but it is tedious.
What I need is a plugin or something for Illustrator 10 that means that I can cut directly. (Even without a specific driver I can use HPGL.)
So can someone point me in the right direction for an Illustrator 10 cutter plugin?
Ray
Chris Wool replied 21 years, 7 months ago 6 Members · 14 Replies -
Graphtec supply a diddy program for cutting from Illustrator, I’ll look it up 😀
Cheers, Dewi
Its called the Graphtec Cutting Master v3.0 for Adobe Illustrator. Unsure whether it would work with your plotter, but I should imagine its available at the Graphtex website, http://www.graphtecgb.com
Cheers, Dewi
Hi Dewi,
I looked at the site and its no good, all you can download is an upgrade which won’t install unless you have the original plugin which comes with a Graphtec cutter – which I don’t have. Do you have a copy you can mail me to see if it works – it might if it has HPGL output. I don’t know if GCC Pumas are compatible with Graphtec.
Ray
Its at the shop Ray, I’ll send it over in the morning. Want to PM me your email details? 😀
Cheers, Dewi
I use a plug-in for Illustrator, well I use it in Freehand but its meant for Illustrator. Try this.
http://www.magisign.com/US/dwld/dwld.html
I use the freebie basic one, its splendid.
I could be wrong ( 😀 ) but I was thinking that most plug-ins are cross platform. All it takes is for Illustrator to recognise it. Actually as I write this it sounds wrong.
So it does, I remember I had to dig out my old Mac in order to use it. Not that Im tight or nuffink 😉
ok so whats the difference between a plug in and a printer driver
confused of saltash (?)
chris -
I always think of a plug in as something that puts a function/s within the base programme and a printer driver you just print to a cutting device as opposed to a printer.
Alan -
thank you for that so i presume that there is no windows driver for the plotter they are talking about which would do whot they require.
chris -
I’ve just been to the Graphtec site and under support there are loads of Windows drivers for various Graphtec plotter models and os, is the GCC Puma a Graphtec compatible model though?
Alan -
This was lifted from the site below
Windows Driver
Puma II includes a Windows driver that allows sign makers to edit signs from CorelDraw and output directly to Puma II. It is very simple and easy to make signs with Puma II.http://www.teksys.com.au/products/pumaII/?C1=9&C2=24
although the language is HPGL every type of plotter has a different set up string before the plot info – i did not find a puma support site
