Home Forums Vinyl Cutter Discussions General Cutter topics cutter plotter advice needed
  • cutter plotter advice needed
    Posted by Paul Savage on 22 December 2010 at 20:22
    Hi guys, ive wondered here looking for advice, at present my wife and i run a small wedding stationary business and have been given a craft robo cutter with which we can cut small favour boxes.
    Now i have started on a small scale for now producing vinyl stickers for car clubs, urls and the like and the craft robo is fine for this.
    Now the craft robo cc200-20 we have is fine at cutting but if you want to print and cut its useless, thats not just my opinion but the opinion of everyone ive asked about them, the reason being that although you can print the registration marks the cutter will not pick them up.
    So my question to you is, what is the best low budget system that will allow my to print and then cut card and vinyl
    Peter Normington replied 14 years, 11 months ago 8 Members · 17 Replies
  • 17 Replies
    22 December 2010 at 21:01
    Hi Paul
    welcome to the boards,
    The first thing you need to know is that card and vinyl are entirely different.
    In general terms to print and cut outdoor durable vinyl then you need a solvent machine like the roland versacam, an entry level machine at around 8k,
  • Paul Savage
    22 December 2010 at 21:16
    Totally understand that vinyl and card are different but the craft robo cuts both fine so there should be other machines out there, im not talking thick card here, something like a birthday card thickness.
    printable vinyl ive never used but only looking at interior grade.
  • David Rogers
    22 December 2010 at 22:17
    Could always try picking up an old Roland ColorCamm as it’s more suited to the low volume market (being expensive to run).
    23 December 2010 at 13:39
    Paul, the craft robo is what it says a hobby machine so it may well be that there isn’t another machine out there or not one that works any better.
    I have to be honest and say that I’m not really sure how it works but I believe it uses a carrier sheet when cutting. If you bought another plotter it would be a bigger machine and these don’t use a carrier sheet the same so cutting through card could easily damage the machine bed or the blades. You could probably adapt it so it worked the same way but I doubt if anyone on here has done that.
  • Paul Savage
    23 December 2010 at 14:16
    Yeah it is a hobby machine and uses a carrier sheet but has its limitations.
    What i want to do is print on vinyl and then cut it around the print, to do doming, ie keyrings etc
    The problem with the craftrobo is its useless at finding the registration marks and with all the research ive done its not just me, everyone seems to have the problem.
    Vinyl cutting is the other thing im trying out and hope to buy a bigger machine next year and dont mind a bigger and better machine for that so if anyone can point me at a reasonably priced starting point i would be grateful.
    23 December 2010 at 15:01
    you can use the carrier system on the bigger machines but never felt the need.
    i thought that the craft had the same eye as my big graphtec which can be very accurate and a joy to use.
  • Paul Savage
    23 December 2010 at 15:10
    i wish it was so but i cant get it to find the registration marks, even following the online tutorial on the graphtec site word for word. Ive been on other sites more craftrobo type sites and they all have the same problem with 1001 different sulotions the main one being to make sure everything is dead straight, i couldnt get it any straighter if i tried but still it wont find them.
    Im at a lose really as doming is what i want to get into as well as vinyl cutting.
  • Paul Savage
    23 December 2010 at 18:58
    quote DavidRogers:
    Looks just what im after, but why is it expensive to run?
  • Jason Davies
    23 December 2010 at 19:02
    Paul, which software are you using with the craftrobo. It is fairly accurate and easy to use. A little annoying at times though. I have used these systems with primary school children with printed card and vinyl (which John Childs kindly donated) with great success.
    23 December 2010 at 19:04
    it uses thermal ribbons, much more expensive per square unit than ink.
    It depends by your definition of cheap, to compete in the doming market you will need to invest several thousand pounds at least.
    just had a little read of the craft manual and see that it uses cutting master
    which i found totally unusable on my big graphtec far too much hassle. and no real control over whats happening.
    i do some doming and use either a thermal or solvent printer depending on what the design is.
    keyrings are a doddle with a laser but can be expensive to up keep
  • Jason Davies
    23 December 2010 at 19:09
    Hi Chris, as far as I am aware you can only use cutting master to cut using the registration marks. If I remember rightly it won’t let you import the standard files either (e.g e.p.s) but the new version might?
  • Nigel Pugh
    23 December 2010 at 19:30
    Please don’t take this as promoting but GCC are bringing out a add on / optional extra for their cutters, basically it is just a front and back plate that you screw onto the cutter making a extended flat bed just for cutting around printed card, I cannot give any extra info as I’m now on holiday.
  • Paul Savage
    23 December 2010 at 19:40
    quote Jason Davies:
    Just the basic package that came with it, cutting master 2, not design master 2
    23 December 2010 at 22:58
    quote Nigel Pugh – Grafityp:
    currently looking at that idea for when cutting moto x stuff.
    i have said it before and the only thing compatible with cutting master is a dust bin.
    i can tell the graphtec fc7000 130 to find my printed marks and calibrate the box distance to the print distance. then send a cut file.
    as my roland was struggling to cut moto x 300mil laminate i had to find a way to do it on the graphtec but by pass CM2 and the stupid macro in corel to print marks.
  • Gavin Conway
    24 December 2010 at 22:38
    Hi Paul – my tuppence worth for you….
    I’m a self taught fairly newbie to signs and my remedy for the craft Robbo not seeing the registration marks is simple to overcome.. just make your own dots etc and cut these with each layer – thats all a reg mark is…
    Merry Christmas to everyone on the forum… Gavin
    24 December 2010 at 23:29
    Gavin
    I may be wrong but I think in this case the reg marks are to contour cut print, not to layer vinyl
    Merry xmas
