Home Forums Vinyl Cutter Discussions General Cutter topics Cutter not cutting full letters, help needed?
  • Cutter not cutting full letters, help needed?
    Posted by Aaron Powell on 8 February 2009 at 11:55
    Any idea why my cutter is not cutting full letters it always stop about 2mm away from the starting point?
    Any idea why
    i have artcut software(i know not the best but it worked fine b4)
    and a 53"cutter
    mod-edit
    please use descriptive topic titles when posting
    this post has now been edited.
    Aaron Powell replied 16 years, 11 months ago 3 Members · 6 Replies
  • Nigel Hindley
    8 February 2009 at 12:01
    This happens to us sometimes I don’t always know why but sometimes its simply a bit of vinyl stuck to the plotter and this creates a wee are that doesn’t cut?
  • Aaron Powell
    8 February 2009 at 12:04
    The vinyl is loose when going into the cutter
  • Nigel Hindley
    8 February 2009 at 12:10
    Sorry Aaron – I mean just a wee tiny bit stuck down on top of the plotter not the actual vinyl being put into the plotter? it makes the blade jump? if you see what I mean?
  • Harry Cleary
    8 February 2009 at 12:21
    If it isn’t completing letters then it is likely to be your ‘blade offset’ settings. Not sure where they are in your software but you need to adjust them and run tests to make sure it is set right.
  • Aaron Powell
    8 February 2009 at 12:29
    Running test at the mo but havn’t a clue what i’m doing lol
    Cheers anyway
  • Aaron Powell
    8 February 2009 at 12:43
    GOT IT WOOO HOOO
    I’m glad i joined uksb
    The problem was in the software the plotter was set 0mm and it needed to be 2mm
