Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters cutter moving as if cutting but not!!
  • cutter moving as if cutting but not!!
    Posted by Tracey Vaughan on 11 June 2009 at 16:53
    firstly can i thank you for all your previous help,after months of messing and just about to give up i eventually got my cutter working wippee!!!
    i was over moon it seemed i had to many cutting software on the computer which was confusing the cutter,
    any way been practicing on scraps of normal vinyl and seemed to cut ok think i need to slightly change settings as not cutting all way through,
    so when i put t shirt vinyl the cutter is making all the cutting motions but not cutting through the vinyl any help as normal would be great thanks
    tracey
    Tracey Vaughan replied 16 years, 6 months ago 4 Members · 9 Replies
  • 9 Replies
  • John Wilson
    11 June 2009 at 17:10
    Garment vinyl is thicker so it needs more pressure
  • Tracey Vaughan
    11 June 2009 at 17:36
    thanks any recommendations,
    tracey
  • Chris Windebank
    11 June 2009 at 19:23
    i use the same pressure for vinyl and t shirt material, have you got it the right side up?
  • Tracey Vaughan
    12 June 2009 at 16:05
    thanks yes pressure was problem thank you,
    tracey
  • John Wilson
    12 June 2009 at 16:12
    No problem
  • Tracey Vaughan
    13 June 2009 at 19:52
    thanks john got cutter working the only issue i have been left with is
    the lettering looks great but i have lines cut across some letters which show up on dark and coloreds is this just another simple thing that i have missed.
    tracey
  • Gordon Forbes
    14 June 2009 at 01:28
    Look at the lettering in your program with no fill and see where the lines come from. Do they overlap and if so did you do a "weld" to create a new outline. if you explain things a bit better people will help more I would say.
  • Gordon Forbes
    14 June 2009 at 01:31
    Reading your post why have you "Too many cutting program’s? I wonder.
    Anyway if you read the help files in these it will explain everything that is if they have the help files with them.
  • Tracey Vaughan
    14 June 2009 at 09:16
    sorry by to many cutting programs i mean i got one with the cutter, i downloaded a couple of free trial ones, and because none would work i bought a couple to try, but i did not take all of them off the computer and try one at a time because some were downloads, then i thought sod it took all of them off and the first one i tried on its own worked.
    because i am not technical i only outline questions short as to receive a short uncomplex replies if that makes sense.
    as i said in another post i have opened a small t shirt printing shop so this forum has been a life line to me in the help i have received, unfortunately their is no guide book on any business and all the question helps others as well as those who ask them.
    again thank you
    tracey
