Home Forums Vinyl Cutter Discussions General Cutter topics Cut using HPGL/2 commands
  • Cut using HPGL/2 commands
    Posted by Graeme Harrold on 22 August 2007 at 13:36
    Ive just spent the last 2 hours trying to set up WinPlot to communicate with a Summa D1010 cutter. It would cut a couple of correct lines or characters then throw in some wierd lines then stop ( also fed a complete roll, 15m, of vinyl through the machine). I would then run the same job again and all it would do was cut a little more of the 1st job and stop again………
    Needless to say when the battery low light on my laptop started flashing, I installed a default HP plotter (Printer driver), switched the cutter to accept the command format and cut my set graphic 1st time…………
    1. I fear this is a communications problem between WinPlot and the cutter
    and
    2. I do not have endless time to keep trying to set up Winplot.
    Therefore the question…….Is there a downside to using a HPGL plotter driver and the print command against using cutting software???
    I will keep going until I find a problem, but as I’m doing small single layer graphics I haven’t come across any downsides yet. If anyone has please let me know.
    christoph rihs replied 8 years, 7 months ago 2 Members · 2 Replies
    22 August 2007 at 14:00
    hi
    DMPL is normally the default if i remember which when driven down the serial will allow some extra commands Polling for example.
    if your happy as is now carry on.
    the plot fault you described sounds like the flow control which used to be set to hardware. i have not had a summa for years but good machines
  • christoph rihs
    22 May 2017 at 05:46
    Hi Graeme,
    since I am trying to set up an old Summa D1010 and having difficulties getting anything out, I stumbled upon your post here.
    Just wanted to ask you what hp driver you used and what you meant by "switched the cutter to accept the command format" – could you explain that a bit more in depth, please?
    best regards – Christoph
