Home › Forums › Vinyl Cutter Discussions › Roland Cutters › cut path in illy cs4
Posted by George Elsmore on 23 March 2010 at 07:23Morning All can someone walk me through the versa pallette to versa and how to make a cut path in illy please please
Ta
G
Jason Davies replied 15 years, 9 months ago 3 Members · 4 Replies -
I dont know about versa works but this may help?
http://www.zebrastyle.com/orders/illustrator.html
Peter -
George, it’s in the handbook somewhere, ours was automatically setup when we installed the software, I’m sure there was an option. It appears under swatch libraries in its own palette titled roland versaworks. Probably doesn’t help but maybe worth re-installing.
Jason -
Cheers fellows right here is the reason i was asking i have setup coreldraw and illustrator with the cutpaths as per handbook for versaworks. If i create a cut only image in illy and save as eps then open in versa all is well it rips and cuts the image. if i create a cut only image in coreldraw export as eps bring into versa you can see the marching ants (if you know what i mean) when you rip for cutting it crashes versa ???
Get this though if i take the image from corel into illy change to cutpath in illy then save back the file and open in versa it rips and cuts.
I have checked the settings for export as eps in coreldraw a thousand times and all seems correct but versa will not have it
any ideas people as I use corel I dont want to be taking everything into illy just to get it to cut???
Phew
G
