Home Forums Printing Discussions General Printing Topics cut lines on Gerber Composer 2
  • cut lines on Gerber Composer 2
    Posted by rosette on 14 December 2003 at 17:50
    I am slowly getting into the software for my Edge2 but I come across a problem which is beating me.
    If I import a vector image from a clip art source, or an .ai file which I want to print but not cut, I cannot get all the cut lines switched off. The programme comes up with a message that some lines are ‘cut only and cannot be switched off’.
    Is there a way round this?
    Eddie Prentice
    Bob Gilliland replied 21 years, 11 months ago 1 Member · 2 Replies
  • Bob Gilliland
    14 December 2003 at 18:23
    Eddie,
    In order for an object to not be a cut based object, it must contain a print attribute. This printing attribute can be in the form of a Fill, Stroke, or both. Once that attribute has been set, it is then possible to “turn off” cut assignments (quick way to turn Cut Off is by pressing the [8] key on the keyboard).
    If there are areas in the design you do not want to cut, but also wish not to have any printed “color”, assign that object(s) a “Clear” Fill, Stroke, or both (depending on the design and effects desired). “Clear” is still considered a print attribute, however, that object will print “nothing” and still allow the cuts to be turned off. 😉
    Be happy to answer any follow up you may have. 😀
  • Bob Gilliland
    15 December 2003 at 11:34
    Thought of some additional stuff that may help to identify some “potential” issues before they become “reality”. Not sure if you’re aware of this or not, and if so, it may be of benefit to others just starting out and reading this.
    When in wireframe view (or “non” filled mode) inside Composer, the vector “color” representation gives a little insight about the object.
    If the outline is represented in Black, it is a “Cut Only” object
    If the outline is represented in Green, it is a “Print and Cut ” object
    If the outline is represented in Red, it is a “Print Only” object
    There are some other colors (Blue and Purple) that display if using the antiquated (but still usable) Graphix Advantage program depending on some other settings, however, inside the Omega package, they have been dropped.
    Take a look at the design in wireframe view before sending it out to GSPPlot. If you have any Black or Green vectors where you don’t want to cut, a little more work is going to be required first.
    Another thing that may be beneficial and reduce wasted time and material; have a look at what is going to cut from with GSPPlot. This can be used as a “last check” before starting output (in case something slipped by in the design process) By default, when you enter GSPPlot, “everything” is displayed. If you press [CTRL]+[C] (or go View>Show Cut from the drop down menu), it will display ONLY the objects that will cut. Quick way to make sure you are in fact cutting only what you want to. Small but important reminder, be sure to Show All, or [CTRL]+[A], before dispatching the job to the Edge. What ever is currently displayed on the screen inside GSPPlot is the “only” thing(s) eligible to be sent to a device. Guess how I know that one! 😮
