Home Forums Vinyl Cutter Discussions General Cutter topics Cut lines not meeting when cutting vinyl?
  • Cut lines not meeting when cutting vinyl?
    Posted by P wilk on 13 June 2006 at 19:26
    I have just tried my first few cuts with my newly acquired mini plotter
    When i attempt to weed the excess vinyl, some of the cuts do not join up; making life difficult. I read that adjusting the offset should sort this problem
    But by doing so, what am I actually doing…is it tilting the knife slightly….and if so, how will i know by how much without making loads of trial cuts. Once set will I have to reset this offset every time I use the plotter
    sorry for the dumb questions
    Paul
    Jill Marie Welsh replied 19 years, 6 months ago 4 Members · 4 Replies
    13 June 2006 at 20:01
    Paul,
    Offset has been covered a few time before, for more in depth explanation try a search. but basics of offset are..
    The plotter uses the centre of the blade shaft as a datum point, but because the blade is ground at an angle the point or cutting edge is not at the centre, so by setting the offset, you are telling the plotter to allow a small diference between the centre of the shaft and the cutting edge. once set, you should be able to save the setting as default. If using a new blade the default setting should be ok. in practice if I need to change the offset, its time for a new blade.
    edited to add a link to macky d’s excellent explanation
    http://www.uksignboards.com/viewtopic.p … set#114613
  • P wilk
    13 June 2006 at 21:44
    Thanks…that seems straight forward
    Even tho’ its a new machine, I’ve put a min of offset on and it seems to have helped with the quality of the cuts. I’ve done about a dozen of different shapes and intricasies tonight until I’ve got what looks to me as a decent product 😀
    Paul
  • Adrian Page
    15 June 2006 at 12:25
    What’s a mini plotter?
    Adrian
    15 June 2006 at 13:28
    Something that magic sign elves use….
    or a little person with a vendetta!
    love….Jill
