Home Forums Software Discussions General Software Topics Custome artwork Help
  • Custome artwork Help
    Posted by Dale Hughes on 19 April 2006 at 19:56
    Hi all i have been sent some artwork in .ai format i have opened it in illustrator CS2 but looking at it in outline there is loads of lines through the text and graphic that should not be there i don’t really know allot about illustrator so any help would be greatly appreciated
    Dale
    Marekdlux replied 19 years, 8 months ago 5 Members · 9 Replies
  • 9 Replies
  • Marekdlux
    19 April 2006 at 20:18
    I have one of those 12,000 clip-art images books here at work. Almost every single one I open up has lines going through them and I have to manually go in and edit these if I want to use them for cut vinyl. Maybe they used something like this?
    -Marek
  • Dale Hughes
    19 April 2006 at 20:28
    Hi Marek they had the artwork done by a sign company (notsure were) but he has brought me the artwork so i can put it onto his t-shirts i am not sure how to get rid of the lines as there is so many of them
    Dale
  • Richard Urquhart
    19 April 2006 at 20:30
    i imported the file in to flexi and welded it all came up fine ready to use
    i re saved it for you and have sent it back
    rich 😀 😀 😛
  • Mike Smith
    19 April 2006 at 20:31
    I know this might sound totally mad but did you open or import the designs you were using?
    Thanks Mike
  • Marekdlux
    19 April 2006 at 20:37
    What file?
  • Richard Urquhart
    19 April 2006 at 20:39
    sorry
    i ask for it to be emailed so i could take a look at it but had to pm as my post would have been deleted
  • Dale Hughes
    Richard you are the best thanks mate. Mike i imported it into winpcsign and also imported it into illustrator i thought it was the way i was exporting it from CS2 to illustrator 3 that was causing the problem but it seem not (winpcsign does not seem to see anything above 3)
    Dale
    Export Corel with AI can cause that like on O’s or B’s where there is shapes inside of another shape.
    If thousands of lines then has come from a CAD software.
  • Marekdlux
    19 April 2006 at 21:02
    quote Richard Urquhart:
    sorry
    Oh, gotcha.
    I thought I wasn’t seeing the file or it was posted somewhere else.
    -Marek
