Home Forums Sign Making Discussions Vinyl Curtain side preparation and cost
  • Curtain side preparation and cost
    Posted by Gary Davis on 13 February 2009 at 20:17
    hi guys,
    Have a curtain side to do and never done one before, its a used truck so im guessing the curtain will be pretty grubby.
    how do you prep it other than degrease? does it need an IPA wipedown and do you key it somehow?
    I would appreciate any advice as not sure whether vinyl will be ok or if i should venture into using mask and paint.
    would banner vinyl survive or does it need to be the likes of apa truck vinyl
    thanks in advance
    gary
    Neil Davey replied 16 years, 9 months ago 4 Members · 4 Replies
  • Simon Stonuary
    13 February 2009 at 21:01
    Hi Gary firstly i would say that you will need a few bodies to enable you fit decals to a curtain as you need two people inside the trailer holding a large sheet of ply / mdf giving you a flat surface to press against.As for degreasing i use a alcohol based wipe , doing a test in the corner before i start ,just in case.personally I dont think banner vinyl will be up to the job, apa is very good & sticks like s**t to a blanket
  • Gary Davis
    13 February 2009 at 21:38
    cheers simon, i was considering removing it, if thats not possible will definately use your top tip re the mdf.
    any idea how much it is a metre at 610mm? not used apa before and would like to give customer ball park price this weekend if poss
  • John Childs
    13 February 2009 at 22:13
    Oh dear.
    Banner vinyl will NOT do the job. It can’t take the constant flexing of opening and closing the curtain. You need proper truck curtain vinyl as sold by Avery and APA.
    Even then, then adhesive is only meant to be used on new curtains. It is something to do with the polymers migrating to the surface and it is not reliable on old ones.
    If you have the choice, go with mask and paint, otherwise leave it alone. It will come back to bite you in the @rse, and wind up costing you far more in rectification than the value of the job.
  • Neil Davey
    13 February 2009 at 22:41
    Agree with John on this but make sure if you go down the ‘paint’ route you use INK and not paint.
    Try Apollo or Sericol for the ink.
