Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters ct630 pressure setting query
  • ct630 pressure setting query
    Posted by garethevans68 on 31 March 2009 at 07:12
    Hi guys,
    i was wondering if anyone can give me a bit of advice. My ct630 is cutting, but i have the pressure setting set to maximum (255) and it’s not cutting completely through the vinyl, i still have to cut some edges with my knife. Could this be a blunt blade or should i be looking else where?
    Many Thanks
    Gareth
    garethevans68 replied 16 years, 8 months ago 4 Members · 6 Replies
  • Graeme Harrold
    31 March 2009 at 07:39
    Blunt blade, worn cutting strip or insufficient blade protrusion for starters………….
  • John Davis IOM
    31 March 2009 at 09:36
    I would normally be looking at a third of the pressure say 85-110,
    depending on the material your cutting.
    Check the blade and holder are set up correctly and if your still having problems change the blade for a new one.
    Could of course be a worn cutting strip, has your plotter had much use?
    John.
  • garethevans68
    31 March 2009 at 21:40
    hi guys, thanks for the fast replies, no it’s seen very little use. I’ve tried the blade screwed through fully, so I’m guessing I’ve got a dud blade.
    My next question is where is the best place to get a good quality blade.
    1 April 2009 at 00:41
    If it’s cutting most of the letters/graphics but just leaving bits in corners uncut then it may well be the blade offset that needs adjusting.
  • John Davis IOM
    1 April 2009 at 21:44
    It does sound a bit like the offset is wrong, what software are you using?
    Not sure where I got them from but Mimaki blades will fit a Pcut.
    Just had a quick look on the internet and the UK signboards tool bar, several suppliers to choose from!
    John.
  • garethevans68
    1 April 2009 at 23:18
    its actually everything that it isnt cutting. it nearly cuts it right through, but i still have to run the knife round the letters.
