Home Forums Software Discussions Flexi Sign Software help creating Crop marks for print and cut?
  • help creating Crop marks for print and cut?
    Posted by Kevin Henshaw on 12 October 2021 at 15:43
    if possible could someone advise me on how to do crop marks in Flexi Sign 8 Pro? I will be cutting with a Roland GX24 optical eye.
    I’m only new to this at the minute and would rather not have to spend £5 grand on a Roland BN20 print cut.
    Thank you
    David Stevenson replied 4 years, 2 months ago 3 Members · 4 Replies
  • David Stevenson
    13 October 2021 at 11:46
    Sorry can’t help you with Flexi but I can advise you not to buy a BN20. Possibly the slowest most useless printer Rolands ever produced. No dryer, & has a stupid waste tank that needs replaced at 50 quid a pop (unless you screw it apart, empty it and fill it with sanitary towels 😉 One of our sales reps calls them the boomerang 20 as no sooner have they sold one it’s back for a trade in and upgrade.
  • Kevin Henshaw
    13 October 2021 at 13:01
    Thanks for your reply David, the problem is I’m limited to space could you recommend a print cutter to start out with ?
    I’m please you replied I’m making enquiries about a 1 year old bn20 with computer set up for 4500 of eBay
  • Jamie Wood
    13 October 2021 at 13:16
    If you can at all avoid it, I wouldn’t recommend a BN20. See if you can get a 2nd user Roland or Mimaki print / cut machine. I would also make sure that any machine you bought, would take a minimum of 760 wide rolls, otherwise you’ll probably struggle to get material. If you have space, get a 1370mm wide machine. For a Mimaki, you’d be looking at one of the CJV models for print & cut. I can’t advise on Roland models, as I’ve never had one, but maybe someone else could help.
  • David Stevenson
    13 October 2021 at 16:21
    Unfortunately Kev I haven’t really followed the different models since we changed ours. Previously we’d a Roland SP540 that was absolutely bulletproof. We printed hundreds of thousands of stickers on it without any problems whatsoever. The only thing it ever needed was regular maintenance & servicing. You can get the smaller SP300 but it takes a smaller roll which limits what you can print. You’ll be amazed how quickly your machine isn’t wide enough once jobs start to come in. We’re running 2x 64″ wide machines and still get asked for wider banners.
