Home › Forums › Vinyl Cutter Discussions › PCUT Vinyl Cutters › Creation PCUT CB 730 (New Aug 2011)
Posted by Stuart Macfarlane on 23 August 2011 at 22:31Hi Guys and Girls,
I’ve just upgraded from the Creation CT 630 to the new CB 730 which I’ve got to say has so far been the best upgrade ever!
I can now send jobs from my laptop or PC over blue tooth rather then moving usb cables around!
Just thought I’d start this post to see if anyone else has purchased one and if so I’m more then willing to assist you with any problems you might have.
Kind Regards,
Stuart MacfarlaneRICH HARRISON replied 13 years, 10 months ago 5 Members · 9 Replies -
PS: Here are my new settings that seem to cut 1cm letters perfectly!
Software
Offset: 0.030cm
Overcut: 0.060cmHardware
Cutter Speed: 0005
Cutter Force: 410The above settings are used in combination with JAC Serical range of vinyl but obviously may vary depending on your material and blade depth.
I set my blade by eye and using a credit or debit card make sure it sticks out no further then the full width of the card.
HI Stuart
thank you for taking the time to make these posts mate, much apreciated and i am sure they will help many.
quote Robert Lambie:HI Stuart
Your welcome Robert, I hope they help as I feel this will be the definitive replacement for the old budget CT 630 that is widely sold at the moment.
As mentioned above if anyone has any problems what so ever just drop a reply to this thread and I will try to assist to the best of my ability in helping you get setup.
hi there,
i bought one of these after have both the old cream one and the black and red one.
only prob im having at the moment is the cutting depth its on 100 (thats the lowest) and the blade is only sticking out a small bit and its still cutting through š
quote Jason Duller:hi there,
Hi Jason,
Only three things spring to mind:
1) What is your Cutter Force set to?
2) Are the fans turning on when the machine starts to cut? These fans actually suck the vinyl down keeping it as good as flat.
3) Try reducing the blade by a quarter or even half turn, As a measurement I put a credit card up against mine and its only sticking out 1/2 the thickness of a credit card!
Hope that helps you start trouble shooting!
quote Stuart Macfarlane:quote Jason Duller:hi there,
Hi Jason,
Force is set to 100 the lowest.
Yes the fans are working.
Where software are them setting you are using?
Thanks Jason
quote Jason Duller:quote Stuart Macfarlane:quote Jason Duller:hi there,
Hi Jason,
Thanks Jason
Hi Jason,
Depends on what software your using… I personally use FlexiSign because its what I’ve been using for many years now.
Hi Stuart.
I’m hoping you maybe able to help me, eight weeks ago I brought a PCUT CB 730 but before I could set it up I ended up in hospital, now I’m ready to set it up I find I’ve got no driver disk, I went back to the shop only to find it was burnt out in the riots and is on longer trading,, and just to add to my luck the drivers on the Creation web site don’t work, Iām hoping you may know someone in the UK that has the drivers to download.
Kind Regards
Kevin Cleary -
HI STUART IVE BOUGHT A CREATION CB730 LAST WEEK AND STILL HAVENT GOT IT RUNNING IVE HAD ONLINE HELP/CHAT AND HE COULDNT GET IT WORKING PROPERLY EITHER I,M USING SIGN CUT PRO AND INKSCAPE BUT THE CB730 IS NOT ON THERE M/C LIST IVE MAILED SIGNCUT THEY SAID TO USE CR730 BUT THIS DOSENT WORK. I DONT HAVE ENOUGH KNOWLEDGE TO SORT THIS OUT MYSELF COULD YOU HELP MAYBE
CHEERS RICH
