Home Forums Vinyl Cutter Discussions PCUT Vinyl Cutters creation kcut Ct24 cutting in reverse
  • creation kcut Ct24 cutting in reverse
    Posted by Andy Lamb on 30 July 2010 at 08:50
    ok, due to the demise of my graphtec plotter, i have bought a ct24. cheap and cheerfull.
    Its all installed using flexi 8.1 all linked up and synced in. but when i cut from the production manager, everything is in reverse. I have to set the carrige to the left side of the plotter, and have to place items i want cutting on the left side of the vinyl on the right side of the production manager preview. It also cuts in mirror. Now, all these problems are easy to compensate and get a good end result. But its just annoying, i like things to be right.
    I have search the forums, and found similar problems, but no solutions. Although im sure i did se a post with the exact problem and a solution last week when i was browsing.
    Andy help would be most appreciated.
    Andy
    diditte_l replied 15 years, 3 months ago 1 Member · 1 Reply
  • 1 Reply
  • diditte_l
    1 August 2010 at 13:02
    Pcut machines have the carriage on the left side as the origin of cutting. In production manager the mirror button (and view) should be enabled before sending your work for cutting (if you don’t do this the cutting will be in reverse).
